I have run remote or radiator mounted pumps for years. I usually put them temp sensor in the radiator personally. It can get a bit busy with plumbing for sure.
Meziere makes block adapters and they work great. I have a buddy in Idaho who makes them for me as well but have used both. I also use their pumps.
https://www.meziere.com/Products/Co...k-Adapter-Set-BB-Mopar-to-12-female.aspx
Radiator mounted pump with block adapters on the Stratus
On my Dakota
