Who on here runs a remote water pump on a RB engine? What do you use to adapt the AN hoses to the block? I know that Andy F made some but has discontinued making them. Shogun made a kit many years ago that was two tubes on a flange for each side and a AN fitting on either tube. This was advertised as a reverse flow system. They are no longer in business. CSI (changed to CSR later) made a water pump kit (in the mid 1990's) that used two alum blocks connected by a 1.25" tube with a upper radiator hose connection all made together. This system used a SB Chevy electric water pump that bolted to the alum blocks. This is also no longer available. Indy has a reverse flow manifold that could possibly work, but I don't think that it has a provision for a coolant temp sensor?
Any help or Ideas short of making something from scratch greatly appreciated.
Also, if anyone has one of these obsoleted items laying around, please PM me, I would be interested in them.
Thanks, Brian
