Originally Posted by Kern Dog
Originally Posted by RTSE4ME
Looks similar to the old XV. Wonder how much you lose compared to Prefix med-rise intake.
Might try one.
https://www.holley.com/products/eng...anifolds/cast/single_plane/parts/300-931
That isn't cheap but it is less that the last 4 barrel intake that I priced.
I'm looking at options for a future 5.7 build and I'm considering the costs of carburetor versus EFI.
That intake and a decent 750 VS carb is around $1000. Then I'd need a way to fire the spark plugs. One aftermarket setup used a different front cover with a real distributor and THAT was a spendy route to go.
Using stock EFI with some stand-alone harness is probably cheaper.
https://www.summitracing.com/parts/...47bCAHpsmONExDAK8d4VhZ0a0iqsaArF4EALw_wc
WAY cheaper than the front drive distributor deal...
