Originally Posted by Mr PotatoHead
The pattern looks much like yours...
There you go, thank you! Has to be the way they make the bearings. I will call King again on Monday and see if they will confirm this is normal. Still going to replace the rod bearings because of the one badly scratched one but seems like the mains are OK.
If it was a crank journal finish issue you'd think there would be some sort of damage to the crank journals themselves which there isn't.
'71 Duster
'72 Challenger
'17 Ram 1500
