Originally Posted by Sniper
Wrong self adjuster on that side?
That's a good guess, or installed wrong.
is the ebrake cable possibly sticking on that side?
Your warning light coming on is either Ebrake or pressure differential valve related, Could also be a pinched wire but doubtful. Disconnecting the two wires will identify which is causing the light to come on.
Do keep us posted
