Synthetic oils will leak out of a engine that has no leaks with petroleum based oils I wouldn't switch any old muscle car motor to synthetic oils due to the fact they were designed to run on petroleum oils
Modern synthetics do not cause leaks. Early formulations did, to some extent.
