How is your converter acting? Are you running more RPM on the big end? I have seen them puke a little when the converter slips too much. Had it happen to me. Shift light started staying on after I shifted, and it was puking a little every run. Pulled trans apart you could still see the writing on the clutches, converter fixed it.
