While driving my car down the road, the water temperature rises between 220-235. However when I stop it lowers to 200.....
I have an aluminum radiator with 50/50 mix and an electric fan located between the radiator and the motor (pull fan). 185 thermostat
Where should I start?
You have an electric fan between the rad and the engine mounted fan ???
WHY ????
It doesn't have a manual fan. Just an electric one
Once you get it running again, if the temp problem remains, try sealing ALL the openings around the radiator including the hood to radiator support.
We can then go back to questions on the combination previously asked to try and help.
