Originally Posted by TJP
Originally Posted by MarkZ
With the stock unbaffled tank it would suck air just pulling into a parking lot with a 1/4 tank of fuel.
Unless you were idling for an extended time on a relatively steep slope that is hard to understand. Can you explain a bit more?
I would would say the location / height of the pickup was at fault. I know my Charger would suck air under 1/4 tank when romping on it hard but it wasn't immediate maybe top of 1st or midway through 2nd? beer
Because it is fuel injected it will be very sensitive to fuel supply dips in pressure.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
