Originally Posted by Sniper
Originally Posted by moparx
ain't late model lec-tricks "PHUN" to figger out ? laugh2 panic
beer
If you had the proper scanner you'd have found that drain. easy The tool I use for my BMW will tell what module is drawing current.
You need the proper tools, you don't use a hammer to install a nut.
Not all scanners will do that on all makes/models. I have access to GMs GDS system and it will do CAN bus draw diag. I also have access to Snap-Ons latest Zues scanner...it does not do CAN bus draw diag(on all makes/models). CAN bus stuff was still relatively new in 09 so the access and diag was limited.
