The proper mechanical clutch linkage bolts in, no welding required tsk scope
All the later A,B and E body Mopar's, 1965 to 1974 or so come with the tab welded on the front driver side sub frame near the firewall for the Z bar bolt and stud to fit into scope up
Have you driven a car with one of those hydraulic clutch set up your thinking about buying and using? If not you should twocents scope wrench up
