Originally Posted by Ramman
Originally Posted by Rhinodart
I have a bent trailer axle and have been unable to find a replacement, guess I will be taking it out and trying some of these techniques... weld
Make darn sure your "bent" trailer axle isn't by design.
Yes, I agreed to cut a trailer axle down for a friend. When I started working on the axle I realized it had built in camber. In order for the axle to be right I had to cut and remove the same amount of tube from each side of the bend. It was a pain but it came out well.
