Yes, but it's not off-the-shelf,
It's a custom application and it has consequences you must consider - like higher heat build-up for your drums to dissipate, and the "sticky" lining will tend to "grab" as you come to a halt, even at lower pedal pressures.
Rochester Clutch & Brake, in Rochester NY..
1(585)924-3717
www.rochesterclutch.com
Call them and they will teach you more than you want to know.
You send them your existing shoes and drums so they can apply the hi-performance lining of your choice, then match each shoe to the curvature to the drums, each one is specific.
There's a lot more to their service than just buying a set of brake shoes.. Just sayin'.
Cheers,
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
