Originally Posted by Guitar Jones
I'd like to know if that solenoid has the power to push the throttle open. I would like to find one that would work for bumping the idle up when the a/c compressor kicks on.
Typically you have to give a little pedal-push while key is ON (power to Sol.) to extend the plunger before cranking.
None are meant to Push the carb linkage, only to Hold it.
