YO7_A66:
Does the Holley bracket (P/N 20-9) work with your Holley carb? Or did you need to fabricate your own bracket?
I have a 750 cfm Brawler carb (P/N 67200). It has 2 screw holes near the primary throttle shaft that the bracket attaches to. Attached is a better pic of the bracket and where it attaches on the throttle base plate.
Attached PDF document
hly-20-9.pdf (23 downloads)
