On stock configuration there is no a straight relationship between Ballast and reg, more than just share the same input signal source from Ign switch, but nothing going throught between them.
JUST cranking the Voltage reg can get load coming from ballast by the default on the Chrysler dual circuit ign system design, but that's just for that instant.
With a Charger born in Chrysler assembly plant in Valencia, Venezuela
