Motor that I built
Factory block
383 / 432 .030 over
3.75 Crank
10.4 - 1 Compression
440 Source Kit
Edelbrock E Street 75CC Heads
Comp Cams XE275 HL Cam and Lifters
200 PSI Cold Cranking on all 8 cylinders
16 initial - 18 Mechanical - All in by 2400 RPMs
Run ported vacuum advance on the street
Edelbrock AVS2 800 - Rejetted on the mains and rods
Idles at 650/700 RPMs all day long - 13.5" Vacuum
Factory power brakes , disc front , zero issues
Never mind the wrong dancing dipstick
Been running for about five years now
https://www.youtube.com/watch?v=gjFG6l_Whh8
