if you mean a comp cams "hi-lift 275/287" i don't think it will give you the vacuum you'll want. rocker ratio will come into play and of all the crane iron 1.5's i've ever had they'll be right at 1.6. this is significant when using a hydraulic cam. i'd think about something a little more conservative especially with cast manifolds.
