Originally Posted by GY3
Originally Posted by Dart 500
Originally Posted by cudaman1969
A joke imo
It will be if that ET can't be replicated like the demons 9.65 couldn't. 9.30's-9.40s is probably what it'll run and you'll have to know what you're doing to do it
People that race understand prep, DA, water grains and the limitations of a factory delivered suspension. The numbers are when everything is optimized and you pull off a perfect pass.
I have lots of passes in the 10.20's and only one that is 10.01. Radial prep lately is the biggest issue.
I hear you but they had a demon only event in the winter with a fully prepped track and still not one of the cars hit the 9.65 ET.
