Originally Posted by 572charger
ive been using cometics on my hemi with a f-2 procharger at 21 lbs of boost on pump e85 its all about the tune up !!!!!! i have 160 lb injectors and a fast xfi to control it
How that setup holding up for you @21 lbs of boost work i assume you have an aftermarket block?
