Originally Posted by demon
The trunk floor will slide right in easily from the rear with the the tail panel removed. No need to cut anything.
The trunk floor welds to the tail panel, so it has to be all separated along the length of the tail panel anyway, so the tail panel is 80% removed already.
I have installed may AMD full tail trunk floors.
Have a look at the install post I did on here a few years ago
https://board.moparts.org/ubbthread...irRYUpcVh5HxiP2x4numQq0i7ZX76BiBaEaXadWI
I was wondering how the OP made out with the trunk pan replacement and went back and pulled up the thread. Then I saw your post and link to a post you made nearly 9-1/2 years ago and realized I had even made the comment "that was impressive" !! I wonder if the OP saw it?
Your photos from your thread up up beer up up
Mike
7807517-trunk1.jpg7807520-trunk3 (1).jpg7807525-trunk5.jpg7807532-trunk6.jpg
