if i swap my 727 over to an A518, what has to be done to the shifter linkage to use my original console shifter ? also, what do i need to do to the floor pan ? pictures would be GREAT. TIA to those that have done this, and can help me decide.
I converted my stock shifter to cable & welded & changed the detents
1968 Charger COLD A/C Hilborn EFI 512ci 9.7 compression, Stealth heads, 4.10 gear A518 ODtrans 4100lb,10.93 full street car trim 2020 T/A 392 Stock 11.79 @ 114.5
