Serious Drag And Drive competitors run bushed lifters, and rockers, and the best you can buy. Roller cams are the norm.
I didn't think about bushed rockers too, but that totally makes sense. More wear and friction but less chance of a needle bearing failure.
Metallicreload- thanks for the heads up, I didn't realize T&D made replacements for stock rockers. They have one listed for Edelbrocks so those should work well with Trick Flows.
Maybe it's just easier to hear about them now with the multiple Facebook groups and the youtube coverage but it's surprising how many cars drop out either on day 0 or day 1. Moparpollack, I saw that Chevelle tank as well. I've never seen that happen, ever. I've had a gas tank fall out of a vehicle before but that was due to rust, not from the tank inflating to 3x normal size and popping the straps off!
