Making it loose is easy. In the old days, guys would drill a small hole in the bottom and drain the oil. And put 6 cylinder springs in.
Controlling pitch rotation is harder. Putting it on the bumper and having it crash down and bounce 4 or 5 times is bad.
Your situation dictates how much money you need to spend on shocks.
If the results don't match the theory, change the theory.
