GTX, there is a valve at the top of the box where the pressure line attaches. It’s a plate with two mounting bolts. If you loosen the plate bolts the plate can slide a bit…which makes a BIG difference in how the steering pulls one way or the other.
You adjust this with the wheels hanging in the air, engine idling. Many people don’t know about that adjustment.
Im familiar with the adjustment you mention.
Ive had the front in the air and running. ...it doesn't turn .
Nor does it pull driving down the road
