So it’s safe to say that anything under a 4.500 bore you won’t be able to use the 2.400 or the edelbrock 2.320 intake valve unless you notch the top of the cylinder? Has anyone tried the Indy 426 1RA with the 2.400 valve on any bore size under 4.500 to see if the work? Thanks for the help.
