[s][/s]
Find a local shop that builds and repairs drive shafts for heavy trucks . They can make you one. Luckily here in W Md the shop here builds shafts for the Pro Stick guys. Mine was 250 with the u-joints.
![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif)
Local truck shop makes shafts for me also.
the only thing that makes me apprehensive about using a place that does truck shafts, even if their work is flawless, is the speed at which the shaft is balanced at.
most [?] truck places only balance at the slow[er] shaft speed[s] a truck sees, and not the high rpm needed for a car, especially if an overdrive transmission or gearvendors unit is being used.
