So, just to throw some water on this, does anyone know how the TF270's compare against either the Indy -1 or 325 heads? I can tell you from a flow bench perspective, these top out around 380cfm, and the B1 heads go +420cfm....
TF advertises 350-ish, IIRC
Comparing it to a B1 is a bit apples to oranges, given the B1 requires special pistons, etc., whereas the TF is basically a bolt on.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
