I use a brake vacuum pump or the same tube with wire bent as a hook with the tube taped to it and syphon the liquid out.I was doing this with a Koleno block for the past 15yrs.
GOTBOOST!New improved with Victor heads.
http://www.enginelabs.com/mopar-big-bloc...t-of-necessity/
