Please remember that the purpose of a girdle is to reduce distortion and retain all components in the correct locations.
This is bending resistance, not strength.
This is a function of the material's "Young's modulus of elasticity", aluminum is about 10 million psi, most iron products are about 30 million psi. An aluminum girdle must be much thicker than steel or iron to have the same effect.
Boffin Emeritus
