Not sure the best way to change for E85. Can you change injector flow rate?
If you can change something to compensate for the additional fuel required, next question is, are the injectors large enough to handle that additional flow?
Also, are they stainless internal injectors? If not, can be gummed up rather quickly on E85, even if using the right filter. (6 micron fiberglass)
Changing for e85 is not hard, in the sniper software,go fuel, target A/F ratio, make sure table is in 2d mode, highlight the entire table, Left click, select "Offset selected" Enter *.67. Now everything is at the E85 ratio, you have a starting point.
Joe
