Most production parts are already heat treated so the only thing you can really do to them is external treatments. The WPC process is a lot finer than than standard shotpeening.
A lot of the import cars never had aftermarket support for transmission parts or ring and pinions so it WPC became the trick to making stock parts live in performance applications. I use it a lot on my rotary engine builds.
