Originally Posted by MoparMike1974
I dont recommend using the bushings for the lower hinge. There is a reason the factory only put them in the top hinge. Look around for the kit with oversize pins so you dont need to install bushings. I also recommend replacing the S spring since they are almost always grooved.
Care to explain why that is?
