3G with TTI block hugger shorties, not much clearance from starter.
Still working out kinks of the install, but I may have starter heat soak issue.
Car turns over fast and starts immediately when cold.
Seems to struggle when hot.
Any suggestions on a good material to protect the starter.
Rather not wrap the header, would be near impossible with the motor in the car.
Thx
