You can re-drill the magnum head to accept the LA style intake. I just made a jig to drill the V8 magnum head for any LA style intake. As long as the port layout is the same on both heads. Magnums don’t have a heat crossover to heat up the intake is the only downside. Not sure about the balance if any between the two engines being a V6
