The X block that we have in the shop has a busted front main cap. Replacements don't seem to be available from the usual places for the front cap. Anyone know if main caps are available for the X block? Is the block 2 bolt or 4 bolt? They came either way, if you are looking for all the caps
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, low 10.30’s 1/4 1.41 best 60 foot 6.56 at 104.17
