Re: roller cam, torrington bearing ,and cam button
[Re: bigblk66_coronet]
#3086748
10/17/22 09:25 AM
10/17/22 09:25 AM
Posts: 2,933 A shed in England
Tig
A shed in England
I can remember going through all this too, I ended up grinding the 3 hex bolt heads and using a nylon button on a stock type (chrome) timing cover, as others have done. I always worried when I changed timing cover gaskets as some are thicker or thinner than the original set up one but it never seemed to cause any issue. I used an old stock timing cover with a hole in the appropriate place and a dial gauge to measure the play, this was a long long time ago and I can't remember the figure we were shooting for. If you go to a Jesel belt drive you can set up the play / clearance much more accurately as they are supplied with a selection of shims IIRC. They are expensive but worth it in my opinion.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
Entire Thread
bigblk66_coronet
10/16/22 08:41 PM
bigblk66_coronet
10/16/22 08:42 PM
CSK
10/16/22 08:44 PM
bigblk66_coronet
10/16/22 08:51 PM
Uberpube
10/16/22 09:29 PM
bigblk66_coronet
10/16/22 09:33 PM
AndyF
10/16/22 10:15 PM
bigblk66_coronet
10/16/22 10:18 PM
SV_MOPARS
10/16/22 11:56 PM
bigblk66_coronet
10/17/22 12:07 AM
Stanton
10/17/22 02:51 AM
JohnRR
10/17/22 01:42 PM
GY3
10/17/22 02:34 PM
AndyF
10/17/22 03:16 PM
JohnRR
10/18/22 02:20 PM
Clanton
10/16/22 09:31 PM
jwb123
10/16/22 10:25 PM
Clanton
10/16/22 10:53 PM
fourgearsavoy
10/16/22 11:37 PM
Cab_Burge
10/17/22 05:51 AM
bigblk66_coronet
10/17/22 10:56 PM
Cab_Burge
10/18/22 12:27 AM
Tig
10/17/22 01:25 PM
