Those of you who have altered or radically changed your car's front suspension, in particular you who have changed to Mustang 2 after-market components:
realizing some of the advantageous of these components (more engine bay space for headers/lighter front weight distribution/R&P steering/etc), it makes me consider how fairly easily the T-bar, recip-box alignments/modifications are to keep caster/camber through front suspension travel in a drag race application. From what I have seen, utilizing M2 chassis/geometery does not have those advantages, or am I wrong?!? Seems to me when a well-prepared/set-up Chrysler Corp car leaves the line, the camber (if done properly) stays pretty 'square' to the ground, but I have noticed cars using the M2 components appear to have negative camber as the wheels/tires angle in at the bottom and out at the top when launching and in particular with the "wheels up". There's also the question of bump steer but that's a fairly easy problem to rectify. You folks that are using M2 or similar suspension components, please post your comments from your own/true/personal experiences, and any remedies you have to cure this. I know, this has been brought up in the past but it's always good to hear user's views after some time in use...thanks
