For pushrod oiling? They are supposed to pressure lube the roller bearing as well but the location of the oil hole concerns me as it doesn't meet with the oil band or oil galley. I can't find a single review of these things. I plan to use them on my very mild hydraulic roller cam, .285 lobe lift, because I'm sick and tired of the noisy hydraulics. Thing sounds like an old chevy with a wiped cam lobe at times. Edit: These are the Endure-X solid rollers.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
