I'm in the middle of buying the parts needed to build a 551 C.I. BB Mopar wedge motor with a set of B1-MC heads using a Holley Dominator EFI system with a Vortech V30-123A crank driven super charger using E85 fuel.
Any help on this will be greatly appreciated, such as what parts are good and which parts to stay away from.
I'll buy and use either a Jesel paired shaft rocker arm system or a similar set up from T.D. B1-MC heads prep by CFE, Hogan custom made EFI intake with dual injectors per cylinder, Weldon crank driven mechanical fuel pump, dual line external oiling system, maybe dry sump oiling system later
Koleno high nickel cast iron block, 4.5 bore x 4.375 stroke Bryant full counter balanced crank, rods and pistons type and brand to be determine in the near future.
All help is appreciated, I liked to get this right the first time
THANKS
