Yes. It also threw the ABS light. Changed the sensor in the rear, no change.
The dealer I went to basically wanted me to leave the truck and a blank check. I didn't bite.
My ABS light and the red brake light on cluster comes on too at times, once I turn the ignition off then back on it goes away. I looked at PCM, took cover off back and saw someone had cut-scraped the rubber stuff off down to board, nothing put back in to cover it back up! I had got another one from the pick yard (wouldn’t work on mine, wrong vehicle) time to send it off for reprogram, but where?
