Well, that is pretty much what I did. I'm using the stock cast iron manifolds. I plan on breaking it in on an engine run stand so I'll have to make sure when installing in the car I watch it.
By the way does anyone know what the torque on the hollow center mounting bolt should be, what about using thread locker on it ??? Thanks, Kevin
