I'm not sure if a stock big block valve guide has the same diameter a small block? I had a stock 360 and used 3300 series CAT valve seals on it and worked great. They're for a 3/8" valve stem and was a positive lock on a stock 360 valve guide. I know it's out of the norm, and might not be an option for some people. Just throwing out an alternative.
