Who ever you get make sure they put sealant on the gasket to window frame otherwise there is a good chance it will leak in the rain or if you run water on it, I had a company tell me not to put any sealant and just install the rubber it will be fine, wish i could help you with a name of a place but really there not very hard to do, I as long as you have good trim that fits your car properly.
