Probably be fine. Everyone recommends a slight vertical angle to help keep moisture off the sensor so they don't get thermal shocked. You could ask TTi why the do it that way. They'll probably tell you that they have been doing it for years and nobody has ever had an issue. That is the standard aftermarket answer for all questions.
