All the hemi motors I know of, except the latest Gen 3 motors that I have not work, came with washers on all the plugs.
I have had some of the tubes on the 426 motor tear the sealing surfaces off completely and still work fine with the after market push in tube seals up twocents
I did try running one of those motors several times without the washer and ended putting them back in, especially on iron heads up wrench
