But this diagram shows the front clutch only engaged in drive-low? And rear clutch all the time in forward gears. What gives here?
You're misreading the chart. Drive has three modes, Breakaway (1st gear with no rear band apply), Second and Direct. The front clutch is only engaged in Reverse and Direct. Yes, the rear clutch is applied in all forward gears.
