The only fixed orifice PCV valves available are for Chevy applications so you have to modify the valve cover to work with a Chevy style fixed orifice PCV. In your case it might be easier to just make a fixed orifice restriction to go in the vacuum line from the valve cover to the intake manifold. Just plug the vacuum line and drill a 0.100 hole in the plug.
