Needs to be able to: --> 2500 stall tight converter, 2.50 rear gears in a Mopar dimensioned Ford 9" --> 5000 stall 8" converter, 4.10's in a Dana 60
So, which one is more important? It can't be "right" for both, only a compromise that's less than ideal for either config.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
