Originally Posted by Cab_Burge
looks like an early custom made, ut the choke tower off and other mods,.
That looks like a early double pumper body shruggy
Measure the throttle bores and plates and post those on here so maybe SOMEONE can look them up in Holley on line spec charts work scope up
I agree on what it looks like.
What ignition system? Sounds like when an ecu has a bad ground. Gets worse when hot. Something like a petronix will get wonky when it’s hot wire sees lower voltage when under hood temps go up. Looks like you don’t have a voltage reg hooked up. Running a one wire? Is it charging good at low rpm?
I want my fair share
